Had some welding to do on the axle housing. It was just for aesthetics, there was some pitting that showed once I started cleaning that I didn't like. Now that is done I can finish off the grinding and sanding, then pull the axle shafts and brakes. Then a coat of paint and get the new U-Bolts and cleaned brackets installed. Hopefully I can have it hung from the springs by next Friday and start cleaning the front axle.
Got the rear axle broken down, re-installed the hubs and wheels. Wheeled the axle out of the garage and power washed it. Came out pretty good. The axle is in good shape. Hope to get it sanded and painted this week. Also got the front axle power washed.
Got the rear end painted and found the yoke is damaged. Did locate a new one on Amazon and a guy on FTE is looking to see if he has one. I am hoping for the later since that would be cheaper.
Manny
Post by Manny »
hfdco4 wrote:Got the rear end painted and found the yoke is damaged. Did locate a new one on Amazon and a guy on FTE is looking to see if he has one. I am hoping for the later since that would be cheaper.
What yoke you need a d60 rear yoke. Spines? etc i have some laying around. :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Got the replacement yoke from a buddy on FTE. Got the axle painted and set in place finally. Also got the front axle started.
Here is a pic of the new Yoke!
Got more done today. Painted the U-Bolts and the U-Bolt plates and got the installed. Also removed the stand from the rear of the frame FINALLY!
Got more work done on the Front axle too. Removed the Tie-rods and the top nut on the Ball Joints.
Manny
Post by Manny »
Looking great curious to know how tall your frame will be sitting with new stock springs and all when you get done. Keep it going your almost to a roller!!! :thup:
I am shooting for about 2 inches over stock. That replaces the rear 4" blocks and hopefully gives it an even ride.
Manny
Post by Manny »
hfdco4 wrote:I am shooting for about 2 inches over stock. That replaces the rear 4" blocks and hopefully gives it an even ride.
Sounds like what I am hunting too. Thinking 2" is perfect. Sorry in advance for copying you if it works out perfectly!!! :lol:
Replication is the most sincere form of flattery my friend! If you have any questions let me know and I will try and assist if possible.
Manny
Post by Manny »
hfdco4 wrote:Replication is the most sincere form of flattery my friend! If you have any questions let me know and I will try and assist if possible.
Definately will hit back with you as time goes by. Ride height and tire size is like my biggest argument i have with myself on the highboy. :cry:
67Step4WD
Post by 67Step4WD »
Great thread and great truck! Can't wait to see the outcome!
67 F100 SWB 4WD Custom Cab (In Progress)
1965 Lincoln Continental Convertible
1972 Fiat Spider
1963 MGA
1966 Chevy G10 NoDoor LS Swap
2006 Buell 900 Wide Rear, Chain Drive Short Track Geared
2013 Audi S4 Tuned
1965 Sunbeam Tiger
Way too many other projects.....
Opportunity is missed by most people because it is dressed in overalls and looks like work. -Thomas Edison
I have 37-12-16.5 military tires I am going to be running.
