LOOKING FOR A SLIDER WINDOW
Hi all, i have a 1970 and the slider window is missing a piece of metal on the slider part of the glass so i need that piece or a whole slider however i do not want a black frame i want the silver metal frame.
Re: LOOKING FOR A SLIDER WINDOW
Bumpside factory sliders are a bit rare, I have been looking for a piece of glass for one. What I have found, is the stock that it is made from is the same material as Dentsides used. If you find a 73-79 window, the metal piece you need can be cut to fit the smaller 70 window. This will only work with a factory window, if it doesn't have Carlite glass, it is not factory.
F. Noble, Saskatchewan.
Thank You for the information i can now broaden my search
