Amazon carb throttle to trapeze
- yeye de qiche
Autolite 2150 off Amazon seen here. I’ve connected my throttle return spring to the round knob near the green line. I think the red line is pointing to the larger part where I hook to the trapeze. What do folks use for this bit? I fashioned a rod out of copper pipe, but I’m not happy with it. Is there a standard connection? What’s it called?
Re: Amazon carb throttle to trapeze
It's hard to tell from that picture but you may have them reversed.
The small ball is used for a lot of throttle connections but a rod with a 90 degree bend can go in any of the other holes too.
and the spring can hook to any location in front or back as long as doesn't bind on anything.
- yeye de qiche
So I’ve seen a connection to the ball knob (green) like the picture below. Is that hardware at the auto parts store or a big box like Home Depot? I don’t even know what it’s called.
So the spring I have forward (radiator fan side) of the carb should go the the lower spinner (red)?
Thanks for any help.
The ball connector is called a ball stud and most napa stores used to have them. With few carbs on vehicles they may be scarce.
68 Ranger. 302 Clevor w/ 3 on tree, soon to have front disc brakes.
I noticed today that LMC has a linkage available now.
