70 F-250 cab swap - Continued
- Sharkdance
Continued from this thread: http://www.fordification.com/forum/view ... hp?t=10291
Just took a boatload of pictures of progress this week-end so here they are:
First set is my aprons. Had to cut out the battery tray on the right side due to rust.
Will have to figure out what to weld in for replacement or find a better one.
- Sharkdance
re: 70 F-250 cab swap - Continued
This next set is the core support:
- Sharkdance
- Sharkdance
- Sharkdance
- Sharkdance
- Sharkdance
Doors
- Sharkdance
- trukcrazy
Shark, I am very jealous. I am sure you don't see it from where you are right now with all the work you are doing, but when it is finished we will all be in awe. You have demonstrated an unreal amount of will and determination on this project. Very similar to Keith's with the website. Keep it up and maybe I can join you at a GTG for north Florida and admire your work. Thanks for the added inspiration.
John, #424
1967 F250 crewcab x 2.
2010 Dodge Ram 1500 Sport Quadcab
2008 Challenger SRT8
well done shark, parts are looking good, now you can install the rad support and inners. and you will feel so good looking at your truck coming together. but you better slow down, or you will out run me and my project.
- trukcrazy
In my previous post, I neglected to mention the added inspiration coming from Widegauge's assistance with your project. Thanks Wideguage. By the way, any pictures of your project?
John, #424
for my project check out the "Yellow 72" post.
- binder56jd
way to go SD
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
now serving #235
- SmokeyBear
