I have a 1967 Ford F100 Ranger I purchased a few months ago. I removed the carpet to repair some rust in the floor pans, I noticed when it rains I get a small leak from behind the firewall cover that runs down into the floor pans. Any ideas on where this leak is starting and how do I repair?
Thank You!!
Water Leak in cab??
Water Leak in cab??
- MAK
Re: Water Leak in cab??
Mine was leaking where the wiper arm shaft penetrated the firewall. Gasket had deteriorated and you could see the leak with a flashlight through the glove box door when the box was removed and someone sprayed water on the outside of the cab.
THANKS !! I will start there.
- m-mman
They actually make reproduction gaskets for these things.
Look at all the suppliers catalogues.
1969 F-100 Custom Cab 302 T-85 Overdrive, 3.70 equalock & factory 16" wheels
Could also be leaking inside the cowl area which is prone to rust out
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
