Bouncy Needle
- JL100
Bouncy Needle
I didn't want to "hi-jack" another thread, so forgive me if this is somewhat repetitive sounding. My speedometer needle on my '67 F100 is extremely "bouncy." The only time it stays somewhat still is at a good cruising speed. I haven't taken apart the dash just yet since purchasing the truck, but was wondering if anyone knew of the fix for this? I read on another thread about a gear of some sort, and am assuming that could be the issue...but my Dad always told me that when I assume it just makes an "A** of U & ME", so I'm gonna ask you guys.
Thanks as usual!
1967 Ford F100
4th Owner
300 I-6
Front Disc Brakes
4th Owner
300 I-6
Front Disc Brakes
Re: Bouncy Needle
A guy at work says the same thingJL100 wrote:...but my Dad always told me that when I assume it just makes an "A** of U & ME", so I'm gonna ask you guys.Thanks as usual!
Anyways my truck does the same thing at anything under 25 it seams
-Mike-
ECV 1849
ECV 1849
- Mancar1
Re: Bouncy Needle
Try lubing the cable 1st. If that isn't it check the speedo gear.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- JL100
Re: Bouncy Needle
Thanks for the input guys, I'll try checking on the gear this weekend when I get some time and I'll post back my results. I know a lot of these old trucks have this issue, but the needle on mine is just a little too active to be working right.
1967 Ford F100
4th Owner
300 I-6
Front Disc Brakes
4th Owner
300 I-6
Front Disc Brakes
- sublimer
Re: Bouncy Needle
I'll be interested in the results of this thread. I have the same issue.
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
Moveable Speakers
Re: Bouncy Needle
Most of the time the cable and sheath just need some lubrication. It binds up and releases, binds up and releases making it jump. You can pull the cable from the tranny and speedometer, pull the cable out of the sheath and grease it up good after a good cleaning. If that doesn't fix it then it would be the speedometer head in the dash.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Joshpow
Re: Bouncy Needle
I would lube cable and try that. Under 25 mine is jumpy and the gear is good and the cable is new. Not horrible but jumps. Old one jumped all the time. Ended up having kink in housing. New cable and better but not 100%
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- Aussie_1970
Re: Bouncy Needle
I had the same issue - where the speedo cable screws into the back of the instrument cluster was loose...like really loose..Tightened it up by hand and the problem went away...I thought that was odd but it worked
- Joshpow
Re: Bouncy Needle
Makes sense Aussie_1970. If it got slack there itd not be real stable. Cool idea to mention.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
Re: Bouncy Needle
What type of grease should we put on the cable?
-Mike-
ECV 1849
ECV 1849
Re: Bouncy Needle
i just use plain ol' wheel bearing grease
- 70_F100
Re: Bouncy Needle
I use Lubriplate 105 on speedo cables.
Thick enough to stay on the core, thin enough that it won't cause the cable to bind.
That's not an oil leak
Re: Bouncy Needle
Cool thanks fellas
-Mike-
ECV 1849
ECV 1849
Re: Bouncy Needle
Mine jumps too. I swapped from 3.03 3 speed to a t18 4 speed and used the same gear on the end of the cable. Didn't bounce before, does now. So I am almost certain the gear is not completely compatible.
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- JL100
Re: Bouncy Needle
Just to post up an update. I took out the gauge console and tightened the nut around the speedo cable. Very hard job due to the shortness of the speedo cable running to the back. After tightening (no lubing because I had not bought any) the speedometer hardly jumps at all, BIG improvement! Thanks for the advice everyone.
1967 Ford F100
4th Owner
300 I-6
Front Disc Brakes
4th Owner
300 I-6
Front Disc Brakes
