Shift boot under or over carpet?
- bjde0b
Does anyone have a photo of original carpet and a floor shift boot. Is the boot screwed on over the carpet, cut around the square section and screwed under the carpet or trimed around the circle section and screwed down?
Check out my build. http://s1088.photobucket.com/albums/i336/MyF100/
Re: Shift boot under or over carpet?
the boot will sit directly on the metal hump. then the carpet over that. the trim ring holds the carpet in place
- bjde0b
hmmm. The truck I found the boot in didn't have a trim ring.
- 70_F100
I might be wrong, but I don't think they used a trim ring on bumps, just on dents.
Two ways to think about it. Screw it to the floor, cut the carpet to go around it, and there's a chance the carpet will unravel. Screw it on top of the carpet, and it eliminates carpet unravelling.
I'm going with the latter on mine, since the factory boot has a reinforcement plate molded in. Use black oxide screws, and it should look just fine.
That's not an oil leak
- bjde0b
I think I agree. The truck I took it out of had rubber floor mat and I think it was on top. That was two years ago so hard to remember.
- robroy
Good morning,
While putting this together on my truck a few weeks ago I chose to put the rubber boot on top of the floor mat.
I thought it over and realized that this way, not only would the hole I cut in the floor mat be completely guaranteed to be hidden, but this way it's possible to remove the boot to access the shift cane assembly without disturbing the carpet/mat at all. If the rubber boot is fastened in place under the carpet/mat, then the carpet/mat could be in the way of removing the shift cane in the future, if you ever want to.
Robroy
Robroy
you guys maybe right. i have removed so many dentside boots that i may have thought of the trim right from doing that. i havent ever seena manual floor shift with carpet. so maybe that is the way it goes is on top of the carpet.
