Would you measure how far down your mirror is on the windshield? I'd like to try to put mine in the same place as stock
Thanks in advance
Someone with an original windshield and mirror, please
- My427stang
- flyboy2610
Re: Someone with an original windshield and mirror, please
I would, but Frodo is still in the shop.
Red Green
you'd better be right.
Red Green
- basketcase0302
The bracket on my 71' is the type that mounts onto the metal above the windshield. Don't know if it's original or not? I do know I've seen and heard of several guys here that have the same type mount, (not the newer type as you're referring to).
Sorry I can't help with the measurement.
- Mancar1
Mine is 2 and 3/4" down from the bottom of the gasket. 68 CS.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- My427stang
Thanks Mancar1
- Mancar1
Your welcome, and that is to the top of the mounting bracket.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
That is not original to a 71. I know that much. Not sure what year it is original though. I'd look at my truck but I've had at least two windshields in mine since my dad gave it to me in around 79-80.basketcase0302 wrote:The bracket on my 71' is the type that mounts onto the metal above the windshield. Don't know if it's original or not? I do know I've seen and heard of several guys here that have the same type mount, (not the newer type as you're referring to).
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
I have an original windshield and mirror on my '69... the mirror in a box of parts on my workbench, it fell off for the previous owner. Probably should mount it, but the visibility is so good being up high, and with the nice big side mirrors, I really haven't seen any need.
