What year did the trucks switch from an accellerator hard linkage to a cable linkage, and what, if any, years swap into our Bumps?
TIA!
Accelerator cable
- 71PA_Highboy
Accelerator cable
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- 71PA_Highboy
Re: Accelerator cable
So I was walking around the JY yesterday and it appears there are 2 styles used on the dents... both from square headlight dents... (78/9?)
One is 302 and one style is 351/400.
The 302 style looks a lot more sanitary, so I will go back and pick that one up then the ground freezes... the current swamp conditions make the endeavor unpleasant...
HTH
HTH
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
I don't know the years they changed but I did away with my stock setup on my 71 years ago. The trapeze set up actually has its purpose though. I know that when I stand on my gas peddle I can feel the engine torque through it.
Mine is just a rod from the arm of the peddle to the carb arm with a ball and socket from a later model truck.
Works great but there is a different feel through the gas peddle and the ratio is a lot different.
Clint
Clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- tybob81
Im using a 79 F250 w/400m pedal and cable on my 68 with a 5.0 and 4v holley. Pedal is a little high for my liking(due to the short cable) so I might swap it out for some kind stock trapeze set up.
1968 swb hydroboost, ididit tilt column, Saginaw p/s pump with F series serpentine, all led lights, Vintage Air and painless wiring. 393w, tko600. CV front suspension w/c5 calipers and gt500 rotors. Stock Flexomatic leaf springs with 01 CV 8.8, 3.90 gears and Auburn locker. Custom wood bed floor. Full frame off resto-mod.
