Seatbelt Question
Seatbelt Question
On the 67-72 F100 was there a middle person lap belt or just the driver/passenger lap belt? I have 67 F100 that needs seatbelts medium blue bench seat.
- basketcase0302
Re: Seatbelt Question
Yes.
http://www.fordification.com/library/ma ... _itemId=31
Maybe someone else can pipe in with a little more info. Isn't that about when Ford started calling our trucks the "three man cab"?
- Kurt Combs
All I saw in those pictures was drivers and passenger lap belts. Maybe they started the 3 man lap belt on the 70 F100.basketcase0302 wrote:Yes.
Ok, I found all the answers In needed for this question.
1)67 was just a 2 lap belts
2)3rd lap belt was available as a dealer accessory or at the parts counter in 1968.
So how did the seatbelts release when latched together? Button or pulled on part of the latch to release it?
- Calfdemon
The stock belts in my buddy's 67 were button release.
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
My '70 looks like it had the center belt added later. The driver and passenger are push button and the center is an old chrome latch, not the newer chrome latches on the aftermarket replacements.
- Mancar1
My 68 Ranger C.S. has three. Button, latch, button.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
My 71 F100 Sport Custom only has the passenger and driver belts.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- couchcuts
Hi, I have a few questions for those that have three seat belts...
Does the middle seat belt use the same bolt connections as the passenger and driver side belts?
right now my '70 has driver and passenger side lap belts.
My plan is adding a middle seat lap belt and two shoulder belts for the driver and passenger side.
I have been doing my homework and getting ready for my seatbelt project....
robroy does a great job explaining the process for the shoulder belts......
http://www.fordification.com/forum/view ... &sk=t&sd=a
you can see the label diagram from the seatbelt maker warning against using two connections to one bolt.
is that safe? Do I have to drill a new connection?
thanks
thanks
http://www.fordification.com/forum/view ... 22&t=64227
1970 F100 Custom Wimbleton White 240 c6 shortbed
- Calfdemon
I ran a center seat belt from SeatBeltPros with my setup. Our trucks that came with center belts used the driver and passenger side inner bolts for the center belt and this is how I did mine. So the outer holes on each side by the doors held my retractors, and then the inner holes held a connector for the passenger side and drivers side, and then each side of the center belt. So the inner bolts each held 2 belts.
You can drill new holes if you want, but the stock holes are reinforced and the bolts are pretty thick and sizeable. You could replace them with class 8 bolts if you want to make it more secure, but I think you are okay with this setup. The seatbelt company HAS to put those warnings on their belts to reduce liability.
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- couchcuts
Thanks so much, I feel better
I was hoping do it the same way Ford did it originally.
Robroy's diagram from his 72 shop manual showed the center belt coming from the same connection.
I just got a little worried when I saw the warning label
I definitely want to get this project correct.
