Help needed!!!!!!, I took apart the steering colume on my 67 f100 to re build it with new part. The steering wheel is not original so I want to replace with an original too, the horn wireing is good but it been rerouted out side the colume, and so has the turn signal switch, it's got a heavy duty switch mounted outside of the colume. The problem is that I am not very familiar with what I would need to buy for the colume and to make the horn work.Any help and/or pictures on how to put everything back to original would be appreciate. THANKS
OR IF ANYBODY OUT THERE HAS ONE IN GOOD CONDITION AND IS WILLING TO SELL IT AT A FARE PRICE LET ME KNOW, THANKS
HELP!!!! Steering colume
- basketcase0302
Re: Steering colume
Hopefully this will help:
http://www.fordification.com/tech/image ... column.jpg
- flyboy2610
Re: HELP!!!! Steering colume
Which steering column do you have? Manual or power steering? Automatic, floor shift, or three on the tree? Also where are you located?
Red Green
you'd better be right.
Red Green
I have a. 3 speed automatic, power steering., and I live in Texas.
- flyboy2610
67F100JMA wrote:I have a. 3 speed automatic, power steering., and I live in Texas.
If you had a three on the tree, manual steering, and lived close to Lincoln, Ne. I could help you.
I hope you find a good column, though!
Red Green
Red Green
THANKS anyways Flyboy2610
- HIO Silver
FYI... 61-63 Falcons use the same steering wheel as the 61-70 F-Series so hit up the Falcon parts houses. A while back they were only $100 but recently went up to around $150.
Here's a source: http://www.falconparts.com/ford-falcon- ... 18p532.htm
Try eBay they have steering columns on there all the time.
