The previous owner of my truck took all weatherstrip off. Is there a weatherstrip that goes around the door and the door opening or just one or the other.
Also where do y'all suggest I buy the weatherstrip? I done need anything fancy, jus wanna keep some of the rain and elements out.
Will
Door weatherstrip ?s
Re: Door weatherstrip ?s
If your worried about fuel prices a Big Block Ford is not for you...
The door gasket is glued to the cab, nothing is actually on the door.
Thanks guys. The help is greatly appreciated.
Will
Will
If you want to get cheap you can get some from a 88 and up chevy pick-up and install them, there the same length as our trucks.
88 and up meaning 88+ I'm assuming? Did you use them? I'll try that out, chebby parts are always cheaper.
Will
Will
