Dash color preference
I have a black dash in my '69, but the rest of the interior is parchment. Were all stock dashes black or were some matched to the interior color? Thoughts on redoing mine in parchment? I think it would look better, but not sure if it would be too reflective while driving. Anyone have a light color dash?
1969 Ford Ranger F250 Camper Special
Project thread http://www.fordification.com/forum/view ... 42#p659842
...I'm picking up good vibrations...
- Subzero
Re: Dash color preference
My truck is Boxwood Green and Wimbledon White below the "bump" and on the roof. My whole interior is Boxwood green, including the metal dash. The gauge cluster is white plastic. I think all dashes were painted like the rest of the interior from factory.
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
Thanks for the reply, sounds like we have nearly identical color schemes inside and out. I am almost positive my truck has had no interior changes before me, but there it is with a black dash.
Do you have any good photos of your interior? Sounds like a beauty!
I think I will do my dash pad in off-white/ parchment using the same color as the new seat vinyl.
- Subzero
Yes, I have a few good ones I took before I made some "improvements" that have yet to be completed ( minor rust repair took priority). I will try and post them tomorrow. I apologize for the late reply too. Like I said I don't think there were any trucks made originally with a black dash. I could be wrong though. The only real way to tell is to see if there is any underlying paint showing through on a chip or scratch, then you'd know it was repainted for sure.
Just to clarify, do you mean the dash pad or the actual dash panel? I re-read your post and I think I may have misinterpreted it. If you mean the dash pad then all were black. The reproductions they sell are also all black. Its the dash panel/glovebox that matches whatever interior truck colors you have.
Thanks for the reply. Yes I meant the dashpad, my actually dash and glovebox are all boxwood.
- Subzero
Here's the picture of my dash. This is right after I got the truck so everything is original still. Sometimes I wish it was that way now but in the near future it will look just as good after all my work is done.
Looks great,but I'm sure it will be better when its been redone!
