wtb t-18/t-19 drive shaft
- mouse
I am looking for the front section of a 2 piece drive shaft that would fit a 71 lwb 2wd with a t-19. any 67-87 regular cab lwb 2wd with the t-18/t-19 will fit
1971 F100 sport special 390 fe
1993 F250 4X4 ext-cab 6.9 idi
- colnago
Re: wtb t-18/t-19 drive shaft
Is there anything unique for a driveshaft to work with a T-18? I'm going from a long-tail to a short-tail C6 within the next month, so I will need a longer driveshaft for my truck. Would the short driveshaft meet your needs? Do you know what size U-joint you need?
Joseph
Joseph
- mouse
there would not be anything special about the drive shaft but would need to be longer than what i got. I am swapping from a short tail c6 to a t19, a t18 is the same and know it needs a longer shaft.
- colnago
Are you selling your short-tail C6 driveshaft? If so, I'm interested.
Joseph
Joseph
- mouse
if I get a longer drive shaft id be willing to sell the one i got and if not would have to get this drive shaft resized
- mouse
I believe it has been found out in the junkyard, it is out of a 85 f350 cab chassis and looks to be about 2-3 inches longer. I will measure out everything to see if its right later
