Need Help- Start Truck No Key
No tech discussion, please
socalcraigster
Post by socalcraigster »
Hi all.
I have a 68 RV (see short video) that does not have a key or the cylinder.
https://youtu.be/NNO86CBXOss
To bypass the ignition, I ran a wire from positive on the ignition coil to the positive battery.
The truck is filled with gas. I add some gas to carb and starts and then dies. I suspect a deficient fuel pump as well. There is spark getting to distributor cap.
Question - Is there a better way to hot wire truck? Is the way I’m doing it okay?
Thanks.
1967 Flareside Shortbed Crew
1969 390 Ranger Long Bed
Re: Need Help- Start Truck No Key
"socalcraigster" Hi all.
Thanks.
Does it still have the points in it? If so you'll fry the points in a short time running straight 12 volts to the coil. The "resistance wiring" coming off of the ignition switch drops the voltage to 9-10 volts for points longevity.
Best to "hot wire it at the ignition switch harness just as your trying to do, (using the same procedure).
Manual or electric fuel pump? :hmm:
Mach428
Post by Mach428 »
I disagree. You can do this for a short period of time, enough to drive it a short distance. The resister wire does drop votage to 9 volts but that's little difference from 12 volt. Besides, points are cheap.
The way you are hot-wiring is correct, again for a short distance. It sounds like you have more of a fuel issue than ignition. Try putting some gas in a spray bottle and gently spray fuel in the carbureatir after it starts. It should stay running long enough to prove your hot-wire theory.
You can buy an add on resistor wire from your local parts store. A little expensive but can save your points.
