tried to change my fuel filter the other day but the housing is stuck. any recommendations? I was thinking of trying an oil filter wrench?
70 f00 2wd ps/pb/ long box 360 auto
thanks
Pete
removing fuel filter housing?
1970 F-100 360 C-6 2WD PS/MB longbox
- jzjames
Re: removing fuel filter housing?
I had to use an oil filter wrench - thay make them in the small size.
I’ve used other types of strap in a pinch.
Just make sure you use the strap based wrench or a huge pair of channel-locks on the bottom edge. You don't want to end up denting or warping the filter housing. They don't need to be excessively tight when reinstalled.
