Fyi pix of factory rear cab bushing
rudsaki
Post by rudsaki »
In case you are trying to rip yours out and wonder how it is put together.
First there is no nut at the bottom because the bottom piece is threaded. This is helpful in removal because once you loosen the bolt up almost all the way you can hammer it from the inside using a socket extension and it will pop right off.
Re: Fyi pix of factory rear cab bushing
Post by cep62 »
rudsaki wrote: Fri Oct 13, 2023 9:45 am and it will pop right off.
Not in Michigan it won't . :D
jzjames
Post by jzjames »
rudsaki wrote: Fri Oct 13, 2023 9:45 am First there is no nut at the bottom because the bottom piece is threaded.
Thanks. I wondered about this for years thinking someone had left the nut off. :?
Thanks for the picture of the setup.
rudsaki
Post by rudsaki »
cep62 wrote: Fri Oct 13, 2023 2:40 pm
Ha, yeah, besides 8 recent years in snow country it was born in San Jose Ca. and stayed in San Jose!
