'72 steering buckles sometimes
krogge
Post by krogge »
Got a 72 F100. At times steering catches/buckles. The entire steering column moves up and down (about 1/2 inch) when it happens. Anything I should check that might cause this?? :) :)
Dwell on the good stuff and you'll always be happy, dwell on the bad stuff and you'll always be angry. Be happy.
Fraser
Re: '72 steering buckles sometimes
Post by Fraser »
Ouch, check for cracks in the frame, around the bolt holes for the steering box. I had a highly abused 76 parts truck which cracked there, but it is not a common failure.
F. Noble, Saskatchewan.
