steering column color
mrollings53
Re: steering column color
Post by mrollings53 »
If you're painting the column anyways; just sand down through however many layers of paint there are leaving it so you can clearly see each layer of paint apart from the next. Once you've hit bare metal one of the first colors of paint is going to be what ever color the column was from the factory. I'm not sure how they painted parts back then, but you should have a layer or two of primer followed by a layer or two of color. Anything after that first or second layer would be someone else's doing.
Common Sense is an Uncommon Virtue
bjde0b
Post by bjde0b »
Good advice. As I said before it was black.
bjde0b
Post by bjde0b »
To close the loop, I decided to do black and I am very satisfied.
ezernut9mm
Post by ezernut9mm »
that's a good color combo. can't go wrong and it looks really good.
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
